SC-OBC Module A1 Software Manual
1. Setup the Development Environment
1.1. Prepare the Software
1.1.1. Target Platform
This document is focused on Ubuntu 24.04 x86_64 systems.
You can use any of the following setups:
A PC with Ubuntu installed
A system container (e.g., Incus)
A virtual machine (e.g., QEMU, VirtualBox, VMware)
Windows Subsystem for Linux (WSL) (see TIP)
For Windows or macOS users, refer to the upstream Zephyr Getting Started Guide.
According to the Install dependencies section on the upstream Zephyr Getting Started Guide, firmware flashing from WSL is not supported. However, for the SC-OBC Module A1 Development Board, we have confirmed that flashing is possible on WSL. Detailed instructions for WSL user are provided in the Connect the Hardware section. |
1.1.2. Install Required Dependencies
| This section is mostly the same as Zephyr official documentation. |
1.1.3. Get Zephyr and Python Requirements
1.1.5. Install udev rules
Install the udev rules, which allow you to flash most Zephyr boards as a regular user.
sudo cp ~/zephyr-sdk-[VERSION]/sysroots/x86_64-pokysdk-linux/usr/share/openocd/contrib/60-openocd.rules \
/etc/udev/rules.d
sudo udevadm control --reload
1.2. Connect the Hardware
Before starting development, make sure you have the following components:
✔️ SC-OBC Module A1
✔️ SC-OBC Module A1 Development Board
✔️ USB Micro-B Cable
✔️ AC Adapter (5V/3.0A PL03B)
Refer to SC-OBC Module A1 Development Board Product Manual for detailed instructions on how to make the connection.
| This document does not require a connection between the MPLAB PICkit and the Platform Cable USB II. |
1.2.1. For WSL User
CON2 on the SC-OBC Module A1 Development Board is the USB Micro-B DEBUG interface and is connected to the onboard FT4232H USB interface. It provides FPGA JTAG, CPU JTAG, FPGA UART, and TRCH UART.
Use a USB cable to connect CON2 to your Windows PC, then attach it to WSL using Microsoft’s USB connection guide.
To attach the device to WSL, run usbipd list on Windows and
identify the FTDI multi-port USB device for CON2 (VID:PID
0403:6011). You need the BUSID from this output for the usbipd
bind and usbipd attach command. The device name may be truncated in
the DEVICE column, but the VID:PID (0403:6011) is sufficient to
identify it.
Example (BUSID may differ on your system):
PS C:\Users\user> usbipd list
Connected:
BUSID VID:PID DEVICE STATE
9-1 0403:6011 USB Serial Converter A, USB Serial Converter B, USB Seria... Not shared
Attach the device to WSL using the BUSID shown by usbipd list:
usbipd bind --busid 9-1
usbipd attach --wsl --busid 9-1
After attaching, the serial ports appear in WSL as /dev/ttyUSB*.
We have confirmed that the west flash command takes longer to complete on WSL compared
to native Linux. (65 KBytes writing: WSL - about 1 minute / Native Linux – about 20 seconds)
2. Try Sample Applications on SC-OBC Module A1
Zephyr provides many so-called sample applications. The Zephyr documentation has a dedicated page called Samples and Demos.
In this section, we’ll build a few samples from Zephyr and run them on your SC-OBC Module A1.
On the Samples and Demos page, you can interactively search samples. There are over 500 samples in Zephyr v4.1.
Using the web interface is much easier than checking each sample’s README.rst.
If you haven’t created your workspace yet, go back to the previous section and do so.
In this section, we assume you have already set up your development environment and are ready to proceed.
2.1. Blinky sample
The first sample is Blinky. This application blinks an LED on your Development Board.
| For the Blinky sample, make sure that SW1[10] (LED control) is turned ON. If it is OFF, the LED will not blink. |
2.2. Hello World sample
Next is the ever-popular Hello World sample. Before running Hello World, we need to set up the serial connection so the module can send output to your PC.
2.2.1. Open Console
Connect the cable between your SC-OBC Module A1 and your PC, then open the console on terminal:
tio /dev/ttyUSB2
| To use the Zephyr console, bit3 (RX) and bit4 (TX) of DIP Switch (SW1) must be turned ON. If they are currently OFF, please switch them ON. |
3. Try developing applications on SC-OBC Module A1
3.1. Introduction
This section explains how to develop applications using Zephyr’s T2 topology.
Several sample applications are provided to help explain the source code structure, build process, and other development practices.
3.2. What is T2 topology
Details of the T2 topology can be found in T2 topology, but it has the following characteristics:
Applications can be managed in a dedicated (custom) repository
Zephyr and other projects can be managed as sub modules
Zephyr drivers can be managed out-of-tree in a dedicated (custom) repository
3.3. Hello World sample
This section provides an example of building and running the simplest Hello World application within a T2 topology-based repository.
The sample application is available in Hello World sample.
3.3.1. Explain the sample code
Directory name
The directory name and structure for the sample application can be chosen freely.
In this example, we use the directory name sample/hello_world.
CMakefile.txt
A CMakeLists.txt file must be placed directly under the application directory.
# Copyright (c) 2025 Space Cubics Inc.
# SPDX-License-Identifier: Apache-2.0
cmake_minimum_required(VERSION 3.20.0)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(hello-world)
target_sources(app PRIVATE src/main.c)
Here, the parts that need to be modified for each application are explained.
project: Specify the desired project name
target_sources: Specify the source code file(s)
prj.conf
Additional Kconfig parameters required for running the application can be specified.
For this Hello World application, no additional parameters are required, so leaving it empty is fine.
# nothing here
Source code
The source code is equivalent to the sample code provided by Zephyr, but the displayed parameters have been modified.
In the Zephyr sample code, CONFIG_BOARD_TARGET was displayed, but in this sample, the board name (CONFIG_BOARD) and the revision (CONFIG_BOARD_REVISION) are displayed separately.
* Copyright (c) 2025 Space Cubics Inc.
* SPDX-License-Identifier: Apache-2.0
#include <stdio.h>
int main(void)
printf("Hello World! %s Rev %s\n", CONFIG_BOARD, CONFIG_BOARD_REVISION);
return 0;
The variable names starting with CONFIG_ store parameters specified in Zephyr’s Kconfig. To know all the Kconfig parameters, you can refer to the ~/myproject/build/zephyr/zephyr.dts file.
3.3.2. Open console
tio /dev/ttyUSB2
3.3.3. Build
Specify the sample application directory where CMakeLists.txt and prj.conf are placed, and then build as shown below.
cd ~/myproject
python3 -m venv ~/zephyrproject/.venv
west build -p always -b scobc_a1 --shield scobc_a1_dev scobc-a1-sample/samples/hello_world
3.3.5. Confirm
After power-cycle the SC-OBC Module A1, you should see the "Hello World" string on the console along with the board name and revision.
*** Booting Zephyr OS build 60e8eb54f7ae ***
Hello World! scobc_a1 Rev 2.0.0
If you want to exit the tio console, first press Ctrl + t, followed by q.
3.4. System Monitor sample
This section provides an example of building and running the System Monitor application within a T2 topology-based repository.
3.4.1. What is the System Monitor
Details of the System Monitor can be found in System Monitor, but it has the following characteristics:
- FPGA Watchdog
The system of the SC-OBC Module A1 is monitored by the TRCH (Timing, Reset, Config & Health Controller), and the FPGA reports its internal status to the TRCH via the watchdog signal.
| the Monitoring by TRCH is disabled by default, so using the FPGA Watchdog feature is not mandatory. |
- SEM Controller
The SEM (Soft Error Mitigation) Controller is a solution provided by AMD for detecting and correcting errors that occur in the configuration memory of AMD FPGAs.
The SC-OBC Module A1 FPGA integrates this functionality into the system and provides access to the SEM Controller’s status through the System Monitor registers. - Board Health Monitor (BHM)
The Board Health Monitor (BHM) is a feature that enables easy retrieval of data from sensors mounted on the SC-OBC Module A1.
The OBC module is equipped with two current and voltage monitors and three temperature sensors.
The BHM allows automatic data acquisition from these sensors without requiring complex I2C operations in software.
System Monitor driver
Currently, the following Zephyr driver APIs are provided for controlling the FPGA’s System Monitor.
| Function | API | Summary | Parameters | Returns |
FPGA Watchdog |
sc_kick_wdt_timer |
Toggle the FPGA Watch Dog Timer |
SEM Controller |
sc_sem_get_error_count |
Get the SEM error count |
Current SEM error count |
Board Health Monitor (BHM) |
sc_bhm_enable |
Enable the monitoring by BHM |
0: Success |
sc_bhm_disable |
Disable the monitoring by BHM |
0: Success |
sc_bhm_get_obc_temp |
Get the on board temperature sensor value |
pos: Position for sensor device |
0: Success |
sc_bhm_get_xadc_temp |
Get the FPGA DAI temperature sensor value |
temp: Temperature [degree] |
0: Success |
sc_bhm_get_obc_cv |
Get the on board Current/Voltage sensor value |
0: Success |
sc_bhm_get_xadc_cv |
Get the FPGA voltage value |
0: Success |
These APIs are provided as an out-of-tree driver and are available in System Monitor Driver.
The sample application is available in System Monitor sample.
3.4.2. Explain the sample code
Directory name
In this example, we use the directory name sample/sysmon.
CMakefile.txt
project(system-monitor)
prj.conf
In this sample, to display temperature data of type float using printf, it is necessary to enable CONFIG_PICOLIBC_IO_FLOAT.
For more information about CONFIG_PICOLIBC_IO_FLOAT, refer to CONFIG_PICOLIBC_IO_FLOAT.
CONFIG_PICOLIBC_IO_FLOAT=y
Source code
The source code is shown below. Details will be explained separately.
#include <zephyr/kernel.h>
#include "sc_sysmon.h"
int main(void)
int ret;
float temp;
int32_t bus;
ret = sc_bhm_enable();
if (ret < 0) {
printf("Failed to enable the Board Health Monitor: %d\n", ret);
goto end;
/* Wait for the first monitoring to finish */
k_sleep(K_SECONDS(1));
while (true) {
ret = sc_bhm_get_obc_temp(SCOBC_A1_TEMP_1, &temp);
if (ret < 0) {
printf("Failed to get the on Board Temperature 1: %d\n", ret);
goto end;
printf("On Board Tempareture 1 : %.4f [deg]\n", (double)temp);
ret = sc_bhm_get_obc_cv(SCOBC_A1_3V3_BUS, &bus);
if (ret < 0) {
printf("Failed to get the 3V3SYS Bus voltage: %d\n", ret);
goto end;
printf("3V3SYS Bus voltage : %d [mv]\n", bus);
end:
sc_bhm_disable();
return ret;
Include System Monitor driver header
Include the header file for the System Monitor driver.
Enable BHM
Enable the System Monitor by FPGA BHM. If a non-zero value is returned, sensor initialization has failed.
if (ret < 0) {
goto end;
Wait 1 seconds
The current System Monitor driver API does not allow customization of the monitoring interval via BHM;
it is fixed at 1 second. Therefore, waits for 1 second until the first data collection is completed.
Get the temperature data from onboard temperature sensor 1 and display it on the console.
If a non-zero value is returned, it may indicate that the temperature sensor data has not been updated within the FPGA.
If you’d like to get other values, try changing the SCOBC_A1_TEMP_1 to a different parameter of your choice, as referenced in Table 1. System Monitor Driver API List
if (ret < 0) {
printf("Failed to get the on Board temperature 1: %d\n", ret);
goto end;
printf("On Board tempareture 1 : %.4f [deg]\n", (double)temp);
Get the on board voltage sensor value
Get the 3V3SYS BUS voltage value data from onboard voltage sensor and display it on the console.
If you’d like to get other values, try changing the SCOBC_A1_3V3_BUS to a different parameter of your choice, as referenced in Table 1. System Monitor Driver API List
if (ret < 0) {
goto end;
3.4.3. Open console
tio /dev/ttyUSB2
3.4.4. Build
cd ~/myproject
west build -p always -b scobc_a1 --shield scobc_a1_dev scobc-a1-sample/samples/sysmon
3.4.6. Confirm
Confirm that the temperature from the on board temperature sensor and the 3V3SYS bus voltage are displayed on the console every second.
On Board Tempareture 1 : 28.5000 [deg]
3V3SYS Bus voltage : 3256 [mv]
4. Device Tree
Before introducing a sample application that uses a Zephyr driver, we believe it is helpful to first explain the Device Tree, as this will aid in understanding the source code more effectively.
4.1. What is the Device Tree?
The Device Tree is a data structure originally developed as part of the Open Firmware specification (IEEE 1275), where it was used to describe the hardware layout of systems such as PowerPC-based workstations and servers.
This concept was later adopted and popularized in the Linux kernel, particularly for platforms like ARM and PowerPC, to enable the kernel to support multiple hardware configurations without requiring separate builds or hardcoded board-specific initialization.
A Device Tree describes the physical components of a system — such as CPUs, memory, buses, and peripheral devices — in a structured and hierarchical format. This hardware description is typically written in a human-readable Device Tree Source (DTS) file, which is compiled into a binary Device Tree Blob (DTB) using the Device Tree Compiler (DTC). The DTB is then passed to the Linux kernel at boot time to guide hardware initialization.
4.2. Device Tree in Zephyr
In Zephyr, the Device Tree model was adopted to improve scalability and modularity across a wide variety of supported boards and SoCs. Unlike in Linux, where the DTB is loaded at runtime, Zephyr parses the DTS at build time to generate static configuration headers.
This enables lightweight and efficient hardware abstraction, while still benefiting from the flexibility and reusability that Device Tree provides.
Hardware Abstraction
Describes hardware outside application code, reducing hardware-specific logic in C files.
Portability
A single source tree can support multiple hardware variants by simply switching DTS files.
Maintainability
Easier to add support for new boards or SoCs without modifying existing drivers or core logic.
Scalability
Makes it easier to manage families of devices with similar but not identical hardware configurations.
4.3. Common Usage of the Device Tree in Zephyr
In Zephyr, the Device Tree is used to:
Define and configure peripherals like UART, I2C, SPI, GPIO, CAN, and more.
Bind drivers to hardware automatically based on compatible strings.
Pass hardware parameters to applications via macros generated from the DTS (e.g., base addresses, interrupts, labels).
Manage multiple board variants using overlays.
4.4. Basic Structure
A Device Tree is structured like a filesystem, with nodes and properties:
Nodes represent hardware components (e.g., /cpu, /memory, /soc/gpio@40020000)
Properties are key-value pairs describing attributes like addresses, interrupts, clocks, and more.
This introduction is a starting point. For deeper understanding, consider reviewing the official Zephyr device tree documentation.
5. Try applications development using Zephyr Driver
5.1. Introduction
This section explains how to develop applications using Zephyr Driver.
Several sample applications are provided to explain how to check the Device Tree and how to use drivers.
5.2. GPIO Driver sample
Using this GPIO driver, the LED on the Development Board will blink. The sample application is available in Blinky sample.
5.2.1. Explain the sample code
Directory Name
In this example, we use the directory name sample/blinky.
CMakefile.txt
project(blinky)
prj.conf
As this example uses GPIO, it is necessary to set CONFIG_GPIO=y.
CONFIG_GPIO=y
Source code
#include <zephyr/drivers/gpio.h>
int main(void)
int ret;
const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(DT_ALIAS(led0), gpios);
int led_state = 0;
if (!gpio_is_ready_dt(&led)) {
printf("GPIO device is not ready\n");
ret = -ENODEV;
goto end;
ret = gpio_pin_configure_dt(&led, GPIO_OUTPUT_ACTIVE);
if (ret < 0) {
printf("Failed to configure a GPIO pin (%d)\n", ret);
goto end;
while (true) {
ret = gpio_pin_toggle_dt(&led);
if (ret < 0) {
printf("Failed to toggle a GPIO pin (%d)\n", ret);
goto end;
led_state = gpio_pin_get_dt(&led);
if (led_state < 0) {
printf("Failed to read GPIO state (%d)\n", led_state);
goto end;
printf("LED state: %s\n", led_state ? "ON" : "OFF");
end:
return ret;
GPIO Device structure
The SC-OBC Module A1 is equipped with AMD (formerly Xilinx)'s AXI GPIO IP core, which connects to 10 GPIOs.
The relationship between the GPIOs and the User IO pins is as follows, with GPIO15 connected to the _LED11_on the Development Board.
| User IO pin name | GPIO name in AMD GPIO IP core |
UIO2_15 |
GPIO15 |
UIO2_14 |
GPIO14 |
UIO2_13 |
GPIO13 |
UIO2_12 |
GPIO12 |
UIO2_11 |
GPIO11 |
UIO2_10 |
GPIO10 |
UIO2_09 |
GPIO9 |
UIO2_08 |
GPIO8 |
UIO2_07 |
GPIO7 |
UIO2_06 |
GPIO6 |
Referring to the DTS overlay file for Development Board, it can be seen that GPIO15 of the GPIO IP core is defined with the device name user_led_0.
Additionally, an led0 is assigned using the alias, which is used by Zephyr’s blinky sample. However, this alias is not mandatory.
aliases {
led0 = &user_led_0;
sw0 = &user_sw_0;
leds {
compatible = "gpio-leds";
user_led_0: led_0 {
gpios = <&gpio0 15 GPIO_ACTIVE_HIGH>;
Therefore, in this example, the GPIO device structure is obtained using GPIO_DT_SPEC_GET and DT_ALIAS.
About GPIO_ACTIVE_HIGH
In the DTS overlay, the user LED is defined as:
On the Development Board, the user LED is driven through an N-channel MOSFET.
When the GPIO pin drives the MOSFET gate HIGH, the MOSFET turns ON and current flows through the LED, causing the LED to light up.
Electrically, this means:
GPIO = 1 (HIGH) → LED ON
GPIO = 0 (LOW) → LED OFF
Therefore, the LED is considered active when the signal is HIGH, which is why
GPIO_ACTIVE_HIGH is used in the Device Tree configuration.
The LED driving circuit can be found in the Development Board schematic (see the LED control circuit in the schematic document):
This configuration allows Zephyr to interpret the GPIO value correctly, so that a logical 1
corresponds to the LED being ON and 0 corresponds to the LED being OFF.
Validate that GPIO port is ready
Validate that GPIO port is ready. If the GPIO device is not properly initialized, it will return false.
ret = -ENODEV;
goto end;
Configure a GPIO pin
The GPIO is configured to its initial state as OUTPUT_ACTIVE. If the configuration fails, a non-zero value will be returned.
if (ret < 0) {
goto end;
Toggle a GPIO pin
Toggle the GPIO pin. If the toggle fails, a non-zero value will be returned.
if (ret < 0) {
goto end;
Read GPIO state
In this sample, the LED state is read back from the GPIO after toggling it.
gpio_pin_get_dt is used to read the logical level of the GPIO pin.
If the read operation fails, a negative value is returned.
goto end;
5.2.2. Open console
tio /dev/ttyUSB2
5.2.3. Build
cd ~/myproject
west build -p always -b scobc_a1 --shield scobc_a1_dev scobc-a1-sample/samples/blinky
5.2.5. Confirm
After power-cycle the SC-OBC Module A1, you should see that the LED11 will blink on and off every second, and the LED state will be displayed on the console.
LED state: OFF
LED state: ON
LED state: OFF
LED state: ON
5.3. I2C Driver sample
Using the I2C driver for the SC-OBC Module A1, this application gets a temperature data from the sensor on the Development Board and displays it on the console. The sample application is available in I2C sample.
5.3.1. Explain the sample code
Directory Name
In this example, we use the directory name sample/i2c.
CMakefile.txt
project(i2c-sample)
prj.conf
As this example uses I2C, it is necessary to set CONFIG_I2C=y.
And, to display temperature data of type float using printf, it is necessary to enable CONFIG_PICOLIBC_IO_FLOAT.
CONFIG_I2C=y
Source code
#include <zephyr/drivers/i2c.h>
#define TMP175_I2C_ADDR (0x4B)
#define TMP175_TEMP_REG (0x00)
int main(void)
int ret;
uint8_t data[2];
float temp;
const struct device *i2c = DEVICE_DT_GET(DT_NODELABEL(i2c0));
if (!device_is_ready(i2c)) {
printf("I2C device is not ready\n");
ret = -ENODEV;;
goto end;
ret = i2c_burst_read(i2c, TMP175_I2C_ADDR, TMP175_TEMP_REG, data, ARRAY_SIZE(data));
if (ret < 0) {
printf("Failed to read from Temperature Sensor (%d)\n", ret);
goto end;
* The TMP175 temperature sensor provides temperature data with a 12-bit, and resolution
* is 0.0625°C. Since the data is transmitted over I2C as 16 bits, the lower 4 bits of
* the second byte should be discarded. For more details, please refer to the TMP175
* datasheet.
data[1] = data[1] >> 4;
temp = (int8_t)data[0] + (float)data[1] * 0.0625f;
printf("Temperature: %.4f [deg]\n", (double)temp);
end:
return ret;
Device structure
To use the I2C driver API, it is necessary to obtain the corresponding device structure.
There are several APIs available for retrieving a device structure, but in this sample, DEVICE_DT_GET and DT_NODELABEL are used.
The label name specified in DT_NODELABEL must match the label defined in the DTS file.
The I2C device connected to the temperature sensor on the Development Board is defined in DTS overlay file for Development Board.
Although tree FPGA I2C cores are available on the Development Board, the temperature sensor is connected to i2c0.
Because the DTS file may be defined across multiple sources via overlays, you may want to inspect the final merged DTS. This merged DTS is available in the following file under the build directory. ~/myproject/build/zephyr/zephyr.dts
Validate that I2C device is ready
Validate that I2C device is ready. If the I2C device is not properly initialized, it will return false.
ret = -ENODEV;;
goto end;
I2C driver API
The APIs provided by the I2C driver are documented in the I2C interface.
In this example, it is necessary to read 2 bytes of temperature data from the sensor, so the i2c_burst_read API is used to perform a multi-byte read from the I2C device.
The second argument specifies the slave address of the I2C device. For the TMP175 temperature sensor used in this example, the slave address is set to 0x4B.
The third argument specifies the register address from which the temperature data will be read.
This register address must be obtained from the TMP175 datasheet.
For TMP175, the temperature register address is 0x00.
Calculate temperature data
The TMP175 temperature data is represented in 12 bits, and its resolution is 0.0625. Therefore, the raw value is converted before being printed to the console.
For more details, please refer to the TMP175 datasheet.
5.3.2. Check the DIP Switch status
| To access the temperature sensor on the Development Board, bit7 (SCL) and bit8 (SDA) of DIP Switch (SW1) must be turned ON. If they are currently OFF, please switch them ON. |
5.3.3. Open console
tio /dev/ttyUSB2
