Interface Specifications
The locations and specifications of each interface on the Dev Board are shown below.
Interface_Layout.svg
Part Number Interface Name Form Factor Remarks
CON1
OBC Connection Interface
Board-to-board connector 80-pin (0.5mm pitch)
Mating cycles: 50 times
CON2
DEBUG Interface
USB Micro-B connector
CON3
FPGA JTAG Interface
6-pin pin header (2.54mm pitch)
Connector not installed
CON4
TRCH ICSP Interface
Right-angle 8-pin pin socket (2.54mm pitch)
CON5
CAN Interface
3-pin terminal block (5.0mm pitch)
CON6
UIO1 Interface
16-pin pin socket (2.54mm pitch)
CON7
UIO1 Power & GND Interface
3-pin VDD pin socket, 3-pin GND pin socket (2.54mm pitch)
CON8
UIO2 Interface
CON9
UIO2 Power & GND Interface
CON10
UIO3 Interface
CON11
UIO3 Power & GND Interface
Pin Socket VDD3-pin, GND3-pin (2.54mm pitch)
CON12
UIO4 Interface
Pin Socket 6-pin (2.54mm pitch)
CON13
UIO4 Power & GND Interface
CON15
SC Bus Host Interface
USB Type-A Connector
CON16
SC Bus Device Interface
USB Micro-B Connector
CON17
Power Input Interface
DC Jack
Compatible Plug: 2.1mm diameter (center positive)
CON18
Power Input Interface (VIN_A)
Terminal Block 2-pin (5.0mm pitch)
CON19
Power Input Interface (VIN_B)
CON20
Power Input Interface (VDD_UIO1)
2-pin Terminal Block (5.0mm Pitch)
CON21
Power Input Interfacee (VDD_UIO2)
CON22
Step-Down DC/DC Converter Output Interface
2-pin Terminal Block (2.54mm Pitch)
JP1
CAN Termination Resistor Switch Interface
JP2
Power Input Switch Interface (VIN_A)
3-pin pin header (2.54mm pitch)
JP3
Power Input Switch Interface (VIN_B)
JP4
Power Input Switch Interface (VDD_UIO1)
JP5
Power Input Switch Interface (VDD_UIO2)
SW1
User Switch
DIP switch
SW2
Main Power Input ON/OFF
Slide switch
LED1~8
Power LEDs
LED (Yellow-green)
LED11
User LED
LED (Yellow-green)
OBC Connection Interface (CON1)
CON1 is the connection interface to the OBC.
Installed Connector: AXK5S80047YG (Panasonic)
Pin Number Pin Name I/O Power Domain Description
VIN_A_P1
Power
OBC Main Power (A System)
VIN_A_P2
Power
OBC main power supply (A system)
VIN_A_P3
Power
4
ULPI_DP
In/Out
SC Bus D+ signal
5
ULPI_DM
In/Out
SC Bus D- signal
6
GND
Power
Power supply (GND)
7
UIO1_00
In/Out
VDD_UIO1
UIO1 Bit 0 signal
8
UIO1_01
In/Out
VDD_UIO1
UIO1 Bit 1 signal
9
UIO1_02
In/Out
VDD_UIO1
UIO1 Bit 2 signal
10
UIO1_03
In/Out
VDD_UIO1
UIO1 Bit 3 signal
11
UIO1_04
In/Out
VDD_UIO1
UIO1 Bit 4 signal
12
UIO1_05
In/Out
VDD_UIO1
UIO1 Bit 5 signal
13
UIO1_06
In/Out
VDD_UIO1
UIO1 Bit 6 signal
14
UIO1_07
In/Out
VDD_UIO1
UIO1 Bit 7 signal
15
GND
Power
Power Supply (GND)
16
UIO1_08
In/Out
VDD_UIO1
UIO1 Bit 8 signal
17
UIO1_09
In/Out
VDD_UIO1
UIO1 Bit 9 signal
18
UIO1_10
In/Out
VDD_UIO1
UIO1 Bit 10 signal
19
UIO1_11
In/Out
VDD_UIO1
UIO1 Bit 11 signal
20
UIO1_12
In/Out
VDD_UIO1
UIO1 Bit 12 signal
21
UIO1_13
In/Out
VDD_UIO1
UIO1 Bit 13 signal
22
UIO1_14
In/Out
VDD_UIO1
UIO1 Bit 14 signal
23
UIO1_15
In/Out
VDD_UIO1
UIO1 Bit 15 signal
24
GND
Power
Power Supply (GND)
25
UIO3_00 / UIIO4_06
In/Out
VDD_3V3_SYS / VDD_3V3_IO[1]
UIO3 Bit 0 Signal. Connection can be changed to UIO4 Bit 6 Signal via hardware option.
26
UIO3_01 / UIIO4_07
In/Out
UIO3 Bit 1 signal. Connection can be changed to UIO4 Bit 7 signal via hardware option.
27
UIO3_02 / UIIO4_08
In/Out
UIO3 Bit 2 signal. Connection can be changed to UIO4 Bit 8 signal via hardware option.
28
UIO4_00
Input
VDD_3V3_IO
UIO4 Bit 0 signal
29
GND
Power
Power Supply (GND)
30
TRCH_UART_TX / UIO4_09
Input
TRCH UART TX signal. Connection to UIO4 Bit 9 signal can be changed via hardware option.
31
TRCH_UART_RX / UIO4_10
Output
TRCH UART RX signal. Connection can be changed to UIO4 Bit 10 signal via hardware option.
32
VDD_3V3_SYS
Power
3.3V power supply from OBC (VDD_3V3_SYS)
33
GND
Power
Power Supply (GND)
34
I2C_EXT_SCL
Input
VDD_3V3_SYS
External I2C SCL signal
35
I2C_EXT_SDA
In/Out
VDD_3V3_SYS
External I2C SDA signal
36
WDOG_OUT / UIO4_11
Input
Watchdog input signal. Connection can be changed to UIO4 Bit 11 signal via hardware option.
37
VDD_3V3_IO_P37
Power
3.3V power from OBC (VDD_3V3_IO)
38
VDD_3V3_IO_P38
Power
39
VDD_UIO1_P39
Power
Power supply for UIO1 (VDD_UIO1)
40
VDD_UIO1_P40
Power
41
VDD_UIO2_P41
Power
Power supply for UIO2 (VDD_UIO2)
42
VDD_UIO2_P42
Power
43
UIO4_05
In/Out
VDD_3V3_IO
UIO4 Bit 5 signal
44
UIO4_04
In/Out
VDD_3V3_IO
UIO4 Bit 4 signal
45
UIO4_03
In/Out
VDD_3V3_IO
UIO4 Bit 3 signal
46
UIO4_02
In/Out
VDD_3V3_IO
UIO4 Bit 2 signal
47
UIO4_01
In/Out
VDD_3V3_IO
UIO4 Bit 1 signal
48
GND
Power
Power Supply (GND)
49
ICSP_PGD
In/Out
VDD_3V3_SYS
TRCH PGD signal
50
ICSP_PGC
In/Out
VDD_3V3_SYS
TRCH PGC signal
51
ICSP_MCLR_B
Output
VDD_3V3_SYS
TRCH MCLR_B signal
52
GND
Power
Power Supply (GND)
53
FPGA_TCK
Output
VDD_3V3_IO
FPGA JTAG TCK signal
54
FPGA_TDO
Input
VDD_3V3_IO
FPGA JTAG TDO signal
55
FPGA_TDI
Output
VDD_3V3_IO
FPGA JTAG TDI signal
56
FPGA_TMS
Output
VDD_3V3_IO
FPGA JTAG TMS signal
57
GND
Power
Power Supply (GND)
58
UIO2_15
In/Out
VDD_UIO2
UIO2 Bit 15 signal
59
UIO2_14
In/Out
VDD_UIO2
UIO2 Bit 14 signal
60
UIO2_13
In/Out
VDD_UIO2
UIO2 Bit 13 signal
61
UIO2_12
In/Out
VDD_UIO2
UIO2 Bit 12 signal
62
UIO2_11
In/Out
VDD_UIO2
UIO2 Bit 11 signal
63
UIO2_10
In/Out
VDD_UIO2
UIO2 Bit 10 signal
64
UIO2_09
In/Out
VDD_UIO2
UIO2 Bit 9 signal
65
UIO2_08
In/Out
VDD_UIO2
UIO2 Bit 8 signal
66
GND
Power
Power Supply (GND)
67
UIO2_07
In/Out
VDD_UIO2
UIO2 Bit 7 signal
68
UIO2_06
In/Out
VDD_UIO2
UIO2 Bit 6 signal
69
UIO2_05
In/Out
VDD_UIO2
UIO2 Bit 5 signal
70
UIO2_04
In/Out
VDD_UIO2
UIO2 Bit 4 signal
71
UIO2_03
In/Out
VDD_UIO2
UIO2 Bit 3 signal
72
UIO2_02
In/Out
VDD_UIO2
UIO2 Bit 2 signal
73
UIO2_01
In/Out
VDD_UIO2
UIO2 Bit 1 signal
74
UIO2_00
In/Out
VDD_UIO2
UIO2 Bit 0信号
75
GND
Power
Power Supply (GND)
76
CANL
In/Out
CAN L Signal
77
CANH
In/Out
CAN H Signal
78
VIN_B_P78
Power
OBC Main Power (B System)
79
VIN_B_P79
Power
80
VIN_B_P80
Power
DEBUG Interface (CON2)
CON2 is the DEBUG interface between the FPGA and TRCH. It implements various debug functions between the FPGA and TRCH via the FT4232H-56Q chip manufactured by FTDI. The channel assignments for the FT4232H are as follows:
Channel Function
A
FPGA JTAG (Equivalent functionality to AMD Platform cable USB II)
B
CPU JTAG
C
FPGA UART
D
TRCH UART
Connecting the DEBUG interface to a PC with Vivado installed enables FPGA programming. Therefore, a separate Platform cable USB II is not required.
Some of these functions require enabling/disabling via the user switch (SW1) described later.
Refer to the user switch (SW1) section for details.
Connector: 105017-0001 (Molex)
FTDI_VBUS
Power
USB Power Input (FTDI_VBUS)
FTDI_USB_DM
In/Out
USB Data Minus Signal
FTDI_USB_DP
In/Out
USB Data Plus Signal
4
FTDI_ID
Input
Not Connected
5
GND
Power
Power (GND)
FPGA JTAG Interface (CON3)
CON3 is a JTAG interface connected to the OBC’s JTAG port. Since it uses the same signal lines (such as FPGA_TMS) as CON2’s Channel A, it cannot be used simultaneously with CON2. Use CON3 when you want to handle JTAG signals directly without using IC2 (do not confuse with I2C).
The following JTAG cables can be connected:
  • AMD (formerly Xilinx) Platform Cable USB II Flying Wire Adapter
  • Digilent JTAG-HS2 Programming Cable
Supported Connector: TSW-106-07-L-S (Samtec)
FPGA_TMS
Input
VDD_3V3_IO
JTAG Mode Selection
FPGA_TDI
Input
VDD_3V3_IO
JTAG Data Input
FPGA_TDO
Output
VDD_3V3_IO
JTAG Data Output
4
FPGA_TCK
Input
VDD_3V3_IO
JTAG Clock
5
GND
Power
Power Supply (GND)
6
VDD_3V3_IO
Power
Power Supply (VDD_3V3_IO)
TRCH ICSP Interface (CON4)
CON4 is the TRCH ICSP interface, connected to the OBC’s ICSP port.
The pin layout is compatible with Microchip’s MPLAB PICkits 4 and 5. Using the included dual-ended long pin header allows direct connection to the main unit.
Connector: SSQ-108-02-G-S-RA (Samtec)
ICSP_MCLR_B
Input
VDD_3V3_SYS
ICSP VPP/MCLR
VDD_3V3_SYS
Power
Power (VDD_3V3_SYS)
GND
Power
Power (GND)
4
ICSP_PGD
Input
VDD_3V3_SYS
ICSP Data Input
5
ICSP_PGC
Input
VDD_3V3_SYS
ICSP Clock
6
NC
Not connected
7
NC
Not connected
8
NC
Not connected
CAN Interface (CON5)
CON5 is a CAN communication interface connected to the OBC’s CAN port.
It enables communication with the TRCH and FPGA on the OBC.
Connector: TB002-500-03BE (Same Sky)
CANL
In/Out
CAN L signal
CANH
In/Out
CAN H signal
GND
Power
Power (GND)
UIO1 Interface (CON6)
CON6 is the UIO1 interface, which connects to the OBC’s UIO1 port.
It connects to the FPGA on the OBC and provides signals free for any use.
Supported Connector: SSQ-116-01-G-S (Samtec)
UIO1_00
In/Out
VDD_UIO1
UIO1 Input/Output
UIO1_01
In/Out
VDD_UIO1
UIO1 Input/Output
UIO1_02
In/Out
VDD_UIO1
UIO1 Input/Output
4
UIO1_03
In/Out
VDD_UIO1
UIO1 Input/Output
5
UIO1_04
In/Out
VDD_UIO1
UIO1 Input/Output
6
UIO1_05
In/Out
VDD_UIO1
UIO1 Input/Output
7
UIO1_06
In/Out
VDD_UIO1
UIO1 Input/Output
8
UIO1_07
In/Out
VDD_UIO1
UIO1 Input/Output
9
UIO1_08
In/Out
VDD_UIO1
UIO1 Input/Output
10
UIO1_09
In/Out
VDD_UIO1
UIO1 Input/Output
11
UIO1_10
In/Out
VDD_UIO1
UIO1 Input/Output
12
UIO1_11
In/Out
VDD_UIO1
UIO1 Input/Output
13
UIO1_12
In/Out
VDD_UIO1
UIO1 Input/Output
14
UIO1_13
In/Out
VDD_UIO1
UIO1 Input/Output
15
UIO1_14
In/Out
VDD_UIO1
UIO1 Input/Output
16
UIO1_15
In/Out
VDD_UIO1
UIO1 Input/Output
UIO1 Power & GND Interface (CON7)
CON7 is the power and GND interface for UIO1.
Supported Connectors: SSQ-103-01-G-S x2 or SSQ-106-01-G-S (Samtec)
Pin Number Pin Name
GND
GND
GND
4
VDD_UIO1
5
VDD_UIO1
6
VDD_UIO1
UIO2 Interface (CON8)
CON8 is the UIO2 interface, connected to the UIO2 port on the OBC.
UIO2_00
In/Out
VDD_UIO2
UIO2 Input/Output
UIO2_01
In/Out
VDD_UIO2
UIO2 Input/Output
UIO2_02
In/Out
VDD_UIO2
UIO2 Input/Output
4
UIO2_03
In/Out
VDD_UIO2
UIO2 Input/Output
5
UIO2_04
In/Out
VDD_UIO2
UIO2 Input/Output
6
UIO2_05
In/Out
VDD_UIO2
UIO2 Input/Output
7
UIO2_06
In/Out
VDD_UIO2
UIO2 Input/Output
8
UIO2_07
In/Out
VDD_UIO2
UIO2 Input/Output
9
UIO2_08
In/Out
VDD_UIO2
UIO2 Input/Output
10
UIO2_09
In/Out
VDD_UIO2
UIO2 Input/Output
11
UIO2_10
In/Out
VDD_UIO2
UIO2 Input/Output
12
UIO2_11
In/Out
VDD_UIO2
UIO2 Input/Output
13
UIO2_12
In/Out
VDD_UIO2
UIO2 Input/Output
14
UIO2_13
In/Out
VDD_UIO2
UIO2 Input/Output
15
UIO2_14
In/Out
VDD_UIO2
UIO2 Input/Output
16
UIO2_15
In/Out
VDD_UIO2
UIO2 Input/Output
UIO2 Power & GND Interface (CON9)
CON9 is the power and GND interface for UIO2.
Pin Number Pin Name
GND
GND
GND
4
VDD_UIO2
5
VDD_UIO2
6
VDD_UIO2
UIO3 Interface (CON10)
CON10 is the Dev Board’s interface for the UIO3, TRCH UART, Watchdog output signal, and External I2C connected to the OBC.
Due to hardware options on the OBC, some signals may be replaced by UIO4. When using these interfaces, be mindful of the differences in power domains.
UIO3_00
In/Out
VDD_3V3_SYS
UIO3 Input/Output
UIO4_06
In/Out
VDD_3V3_IO
UIO4 Input/Output
UIO3_01
In/Out
VDD_3V3_SYS
UIO3 Input/Output
UIO4_07
In/Out
VDD_3V3_IO
UIO4 Input/Output
UIO3_02
In/Out
VDD_3V3_SYS
UIO3 Input/Output
UIO4_08
In/Out
VDD_3V3_IO
UIO4 Input/Output
4
TRCH_UART_TX
Output
VDD_3V3_SYS
TRCH UART TX Signal
UIO4_09
In/Out
VDD_3V3_IO
UIO4 Input/Output
5
TRCH_UART_RX
Input
VDD_3V3_SYS
TRCH UART RX Signal
UIO4_10
In/Out
VDD_3V3_IO
UIO4 Input/Output
6
WDOG_OUT
In/Out
VDD_3V3_SYS
UIO4_11
In/Out
VDD_3V3_IO
UIO4 Input/Output
7
I2C_EXT_SCL
Output
VDD_3V3_SYS
External I2C Clock
8
I2C_EXT_SDA
In/Out
VDD_3V3_SYS
External I2C Data Signal
UIO3 Power & GND Interface (CON11)
CON11 provides power and GND for the UIO3, TRCH UART, Watchdog output signal, and External I2C. For signals selected for UIO4_XX via the OBC’s hardware options, always use the power from the UIO4 Power & GND Interface (CON13).
Pin Number Pin Name
GND
GND
GND
4
VDD_3V3_SYS
5
VDD_3V3_SYS
6
VDD_3V3_SYS
UIO4 Interface (CON12)
CON12 is the UIO4 interface, which connects to the OBC’s UIO4 port.
It connects to the FPGA on the OBC and provides signals freely available for user use. Mountable Connector: SSQ-116-01-G-S (Samtec)
UIO4_00
In/Out
VDD_3V3_IO
UIO4 Input/Output
UIO4_01
In/Out
VDD_3V3_IO
UIO4 Input/Output
UIO4_02
In/Out
VDD_3V3_IO
UIO4 Input/Output
4
UIO4_03
In/Out
VDD_3V3_IO
UIO4 Input/Output
5
UIO4_04
In/Out
VDD_3V3_IO
UIO4 Input/Output
6
UIO4_05
In/Out
VDD_3V3_IO
UIO4 Input/Output
CON13 is the power supply and GND interface for UIO4.
Pin Number Pin Name
GND
GND
GND
4
VDD_3V3_IO
5
VDD_3V3_IO
6
VDD_3V3_IO
SC Bus Host Interface (CON15)
When using the SC Bus, the OBC can function as either a host or a device.
The SC Bus is a feature currently under development by Space Cubics. By implementing a USB core compliant with the ULPI standard on the FPGA, this interface can be used as a USB host.
CON15 is the SC Bus host interface.
The Data (D+/D-) lines are connected to the OBC and are shared with CON16.
VBUS outputs the voltage directly from CON17, but the voltage drops proportionally to the output current. Furthermore, when a USB plug is inserted into CON16, the power switch on the VBUS path is controlled, disconnecting the VBUS output.
Since simultaneous use of CON15 and CON16 is not intended, do not insert a USB plug into CON16 when using CON15.
Connector: 67643-2911 (Molex)
VBUS_A
Power
USB Power Output (VBUS_A)
ULPI_DM
In/Out
USB Data- signal
ULPI_DP
In/Out
USB Data+ signal
4
GND
Power
Power (GND)
SC Bus Device Interface (CON16)
The SC Bus is a feature currently under development by Space Cubics. By implementing a USB core compliant with the ULPI standard on the FPGA, this interface can be used as a USB connection.
CON16 is the device interface for the SC Bus.
The Data (D+/D-) lines are connected to the OBC and shared with CON15.
VBUS is connected to the gate of the FET (Q4) that controls the EN terminal of the power switch on the CON15 VBUS path. Therefore, when VBUS is applied, the CON15 VBUS output is disconnected.
Since simultaneous use of CON15 and CON16 is not intended, do not insert a USB plug into CON15 when using CON16.
VBUS_B
Power
USB Power Input (VBUS_B)
ULPI_DM
In/Out
USB Data- signal
ULPI_DP
In/Out
USB Data+ signal
4
ULPI_ID
Input
Not connected
5
GND
Power
Power (GND)
Power Input Interface (CON17)
CON17 is the +5V power input interface, utilizing a DC jack.
The corresponding AC adapter plug specification is center positive with an outer diameter of 5.5mm and an inner diameter of 2.1mm.
This serves as the primary power source for all components, including the OBC.
Connector: PJ-002AH (Same Sky)
Power Input Interface (VIN_A) (CON18)
CON18 is the +5V power input interface, using a 5mm pitch 2-pin terminal block.
It is used in the following cases:
  • When the user wants to operate the OBC using their own power supply equipment
  • When the user wants to operate the OBC using only VIN_A
  • When using VDD_3V3_DCDC
Additionally, by mounting a 0Ω resistor (3216 size) on R110, voltage can be applied directly to the OBC without passing through the power input protection circuit (IC11).
Connector: TB003-500-P02BE (Same Sky)
Pin Number Pin Name Description
GND
Power Supply (GND)
VIN_A_TRM
Power Supply (Input to VIN_A)
Power Input Interface (VIN_B) (CON19)
CON19 is the +5V power supply input interface, using a 5mm pitch 2-pin terminal block.
Use this in the following cases:
  • When the user wants to operate the OBC using only VIN_B
Additionally, by mounting a 0Ω resistor (3216 size) on R122, it is possible to apply voltage directly to the OBC without passing through the power input protection circuit (IC12).
GND
Power Supply (GND)
VIN_B_TRM
Power (Input to VIN_B)
Power Input Interface (VDD_UIO1) (CON20)
CON20 is the input interface for VDD_UIO1, employing a 5mm pitch 2-pin terminal block.
Use this to set VDD_UIO1 to an arbitrary voltage, rather than using VDD_3V3_IO or VDD_3V3_DCDC.
GND
Power Supply (GND)
VDD_UIO1_TRM
Power (Input to VDD_UIO1)
Power Input Interface (VDD_UIO2) (CON21)
CON21 is the input interface for VDD_UIO2, employing a 5mm pitch 2-pin terminal block.
Use this to set VDD_UIO2 at an arbitrary voltage, rather than using VDD_3V3_IO or VDD_3V3_DCDC.
GND
Power Supply (GND)
VDD_UIO2_TRM
Power Supply (Input to VDD_UIO2)
Buck DC/DC Converter Output Interface (CON22)
CON22 is the output interface for VDD_3V3_DCDC. It is intended for uses other than powering VDD_UIO1 and VDD_UIO2. The maximum output current is 2A.
Mountable Connector: 10129378-902001BLF (Amphenol CS)
GND
Power Supply (GND)
VDD_3V3_DCDC
Power Supply (VDD_3V3_DCDC Output)
CAN Termination Resistor Switching Interface (JP1)
JP1 is an interface that allows you to enable or disable the 120Ω termination resistor on the CAN bus. The OBC does not have a termination resistor installed.
If you want to add a 120Ω termination resistor to the CAN bus, insert the JP1 jumper and short the pins. If termination is provided elsewhere (other than the Dev Board), remove the jumper socket. When the Dev Board is shipped, a jumper socket is inserted on JP1 by default.
Power Input Switching Interface (VIN_A) (JP2)
JP2 is the interface to switch the power input for VIN_A between CON17 or CON18.
Connector: 10129378-903001BLF (Amphenol CS)
5V
Power Supply (Input from CON17)
VIN_A_CM
Power Supply (Common terminal connected to VIN_A)
VIN_A_TRM
Power Supply (Input from CON18)
JP2_Status.svg
Mode Pin Connections Description
Mode1 (Default)
1-2
Supplies power to VIN_A from CON17
Mode2
2-3
Supplies power to VIN_A from CON18
Power Input Switching Interface (VIN_B) (JP3)
JP3 is the interface to switch the power input for VIN_B between CON17 or CON19.
5V
Power supply (input from CON17)
VIN_B_CM
Power Supply (Common terminal connected to VIN_B)
VIN_B_TRM
Power Supply (Input from CON19)
JP3_Status.svg
Mode1 (Default)
1-2
VIN_B input supplied from CON17
Mode2
2-3
VIN_B input supplied from CON19
Power Input Switching Interface (VDD_UIO1) (JP4)
JP4 is the interface that allows power input for VDD_UIO1 to be selected from VDD_3V3_IO, VDD_3V3_DCDC, or CON20.
The default configuration of the Dev Board is set to VDD_3V3_IO via the jumper socket.
Connector: 10129381-906001BLF (Amphenol CS)
Pin Number Pin Name Description Pin Number Pin Name Description
VDD_3V3_IO
Power Supply (VDD_3V3_IO Input)
VDD_UIO1_IN
Power Supply (Common Pin Connected to VDD_UIO1)
VDD_UIO1_IN
4
VDD_3V3_DCDC
Power Supply (VDD_3V3_DCDC Input)
5
VDD_UIO1_TRM
Power Supply (Input from CON20)
6
VDD_UIO1_IN
Power Supply (Common pin connected to VDD_UIO1)
JP4_Status.svg
Mode1 (Default)
1-2
Supplies power to VDD_UIO1 from VDD_3V3_IO
Mode2
3-4
Supplies power to VDD_UIO1 from VDD_3V3_DCDC
Mode3
5-6
Supplies power to VDD_UIO1 from CON20
Power Input Switching Interface (VDD_UIO2) (JP5)
JP5 is the interface that allows power input for VDD_UIO2 to be selected from VDD_3V3_IO, VDD_3V3_DCDC, or CON21.
VDD_3V3_IO
Power (VDD_3V3_IO input)
VDD_UIO2_IN
Power (Common terminal connected to VDD_UIO2)
VDD_UIO2_IN
4
VDD_3V3_DCDC
5
VDD_UIO2_TRM
Power Supply (Input from CON21)
6
VDD_UIO2_IN
JP5_Status.svg
Mode1 (Default)
1-2
Power supply to VDD_UIO2 provided from VDD_3V3_IO
Mode2
3-4
Power supply to VDD_UIO2 provided from VDD_3V3_DCDC
Mode3
5-6
Power supply to VDD_UIO2 provided from CON21
User Switch (SW1)
SW1 is the switch that controls the connection between the OBC and the following circuits:
  • High-Speed USB Bridge FT4232H-56Q (IC2)
  • User Temperature Sensor Circuit (User Temperature Sensor)
  • User-configurable LED circuit (User LED)
In the default configuration, only Bits 3 and 4 are ON; all other bits are OFF. Manually switch the bit that corresponds to the circuit you wish to use.
Use a pointed tool, like tweezers, as it is difficult to operate the switch with your fingers.
The signal line connecting the OBC to SW1 also branches out to the Universal Area. Please be careful when using signal lines connected to the above circuits in the Universal Area.
Parts mounted: 219-10MSTR (CTS Electrocomponents)
SW1_Status.svg
Bit Number Pin Number Pin Name I/O Power Domain Description
1,20
Input
Communication to TRCH UART via USB interface (CON2) (ON: Enable / OFF: Disable)
2,19
Input
3,18
UIO4_04
In/Out
VDD_3V3_IO
Communication to FPGA UART via USB interface (CON2) (ON: Enabled / OFF: Disabled) (※When FPGA UART is assigned to UIO4_03,04)
4
4,17
UIO4_03
In/Out
VDD_3V3_IO
5
5,16
UIO4_02
In/Out
VDD_3V3_IO
Communication to CPU JTAG via USB interface (CON2) (ON: Enabled / OFF: Disabled) (※When CPU JTAG is assigned to UIO4_01,02)
6
6,15
UIO4_01
In/Out
VDD_3V3_IO
7
7,14
I2C_EXT_SCL
Output
VDD_3V3_SYS
Temperature data acquisition from user temperature sensor via external I2C (ON: Enabled / OFF: Disabled)
8
8,13
I2C_EXT_SDA
In/Out
VDD_3V3_SYS
9
9,12
UIO2_14
In/Out
VDD_UIO2
Pull-down resistor (1kΩ) for UIO2_14 (ON: Present / OFF: Absent)
10
10,11
UIO2_15
In/Out
VDD_UIO2
User LED (LED11) control via UIO2_15 (ON: Enabled / OFF: Disabled)
Main Power Input ON/OFF (SW2)
SW2 controls the EN pins of the power input protection circuits (IC11, IC12), providing an interface to connect or disconnect CON17~19 from VIN_A and VIN_B.
Moving the SW2 toggle toward the ‘ON’ side (as indicated by the silk screen on the Dev Board) connects the circuit; moving it toward the ‘OFF’ side disconnects it.
The default configuration is ‘OFF’.
Component: SSSF011700 (Alps Alpine)
SW2_Status.svg
Number Name
Turns the main power OFF.
Turns the main power ON.
Power Supply LEDs (LED1~8)
LED1~8 are status LEDs for each power supply. Illumination indicates a normal status.
Component: SML-D12M8WT86 (ROHM)
Component Number LED Color Corresponding Power Supply
LED1
Yellow-Green
VIN_A
LED2
Yellow-Green
VIN_B
LED3
Yellow-Green
VDD_3V3_SYS
LED4
Yellow-Green
VDD_3V3_IO
LED5
Yellow-Green
VDD_3V3_DCDC
LED6
Yellow-Green
VDD_UIO1
LED7
Yellow-Green
VDD_UIO2
LED8
Yellow-Green
VBUS_A
User LED (LED11)
LED11 is a user-programmable LED.
Component Number LED Color Description
LED11
Yellow-Green
Connected to OBC’s UIO2_15 via SW1
About VDD_UIO
Any voltage can be applied to VDD_UIO1 and VDD_UIO2 for use.
However, the FPGA’s IO power supply must follow the FPGA power-up sequence. Applying voltage after VDD_3V3_IO goes High ensures compliance with the power-up sequence.
The Dev Board incorporates power switches (IC14, IC15) on the VDD_UIO lines to prevent applying FPGA IO voltage without adhering to the power sequence.
Furthermore, due to voltage and current capacity constraints on VDD_3V3_IO, JP4 and JP5 enable switching the power input to VDD_UIO between the following three patterns:
VDD_UIO = VDD_3V3_IO
VDD_UIO-VDD_3V3_IO.svg
VDD_UIO = VDD_3V3_DCDC
VDD_UIO-VDD_DCDC.svg
VDD_UIO = Block Terminal Input
VDD_UIO-TRM.svg
1. Power domains vary depending on hardware options. Refer to the SC-OBC Module A1 Product Manual for details.
